Kev3188
Also, the list isn't in alphabetical order, which as we all know is a sign of impending doom...
no, what it says is that AA wrote the list with JFK in mind and then decided that trying to argue for the value of a hub at JFK when AA is pulling capacity faster than DL can add it doesn't seem like a great argument for success... so they threw in LGA, called it NYC, and it ended up out of alphabetical order.Well, no Kev, you're misinterpreting. The only station that is out of alphabetical order is NYC. Obviously that is the signal that AA has given up attempting to compete with DL in that market, and all NYC (LGA, JFK, EWR) operations will cease before Christmas. It's as plain as day.
Well, of course you would know what happened (and happens) at AA Headquarters better than anyone else. WT, does it even register with you that you come across as a pompous a** most of the time?WorldTraveler said:no, what it says is that AA wrote the list with JFK in mind and then decided that trying to argue for the value of a hub at JFK when AA is pulling capacity faster than DL can add it doesn't seem like a great argument for success... so they threw in LGA, called it NYC, and it ended up out of alphabetical order.
Have you called DL to tell them Boston can no longer be a hub since it has almost no northern flightsWorldTraveler said:and your explanation as to how NYC got ahead of LAX in a list that is otherwise alphabetized is _________________besides AA/US has relatively few flights north of LGA so it is a whole lot harder to call it a hub than other NYC hubs for other airlines or AA's other hubs which are more omnidirectional.
who said BOS is a hub?Have you called DL to tell them Boston can no longer be a hub since it has almost no northern flights
Your logic is amazing how do you make this stuff up
If not all of us will start sending emails to DL corp comm for you
I'm going to step out on a limb and say no he does notjimntx said:Well, of course you would know what happened (and happens) at AA Headquarters better than anyone else. WT, does it even register with you that you come across as a pompous a** most of the time?
