E,
to be honest, your statement about the quality of products buiilt by Airbus, Fokker, and McD-D is disturbing in light of the fact that more than half of the world's large aircraft fleet (certrainly what has been delivered over the past couple years) is NOT Boeing.
I am all for Boeing as much as any American but it is very naive to think that other manufacturers don't build decent products.
Perhaps it has escaped your mind that the 737 has had spectacular fuselage failures (the convertible look doesn't work so well on jet airplanes). Yes, the DC10 dropped an engine and an uncontained engine failure took down another one while some D9s have been flying almost as long as you have been roaming terra firma (perhaps longer).
Perhaps part of AA's dislike for other types is that AA has tried to use them without success - in some cases such as the F100 because AA's costs just didn't work for a 100 seat airplane (other network carriers have removed 100 seaters as well) or for maintenance issues -the FAA said that AA was at fault at least in part because of their maintenance procedures on the D10 engine and M80 wiring issues and AA pilot training and/or response was partly at fault in the A300 accident. So, iis it possible that AA's dislike for some fleet types is related to AA's use of the aircraft?
AA can hold onto its loyalty to Boeing but that loyalty might be costly in terms of being willing to consider other fleet types.
Jim,
I think it made it clear several times in this thread that I understand the there are higher overall costs associated with fleet complexity... . I indeed said that complexity can lower the costs associated with each segment but I also said that the increased complexity does come at higher costs but also provides the opportunity to go after more revenue.
But again, let's focus on the facts of AA's use of AA's 772s rather than trying to argue about principles that are highly subject to context - in the same way I used them before.
According to data submitted to the DOT, AA's 772s are operated on the shortest average stage lengths (4500 miles) compared to CO (5900) and DL (6900) (UA operates its 772s on average on shorter stage lengths but remember that UA has a subfleet of 772As used on domestic routes and the DOT groups the 772A/ER/LR into the same category. AA also operates the 772 for fewer block hours than any other US operator does for its 777s or even the 763ERs. I will acknowledge that AA's large S. American route system drives that lower usage or AA's 77s and 76s but it might also be further evidence that the 777 is more airplane than AA needs for most of its routes - based on weight but also the higher acquisition costs of the 777 relative to the 333. More than 3/4s of AA's int'l flights that are operated by the 772ER could be operated by 333s. Given that the 764 can operate the same 3/4 of routes that the 333 could also operate - although w/ smaller payload - the argument about fleet complexity gets even thinner since the 764 is very largely in common - or can be - with the 763 and 777 which AA both already operate.
Let me make it clear that I don't expect for one minute that AA will decide to go out and buy the 764 or 333. They have made their decision to buy the 789 and that plane will work well - IF they can get the pilots to agree to a new contract that will allow AA to acquire it.
But I am pointing out that increased complexity can indeed result in overall lower SEGMENT costs - and in the case of the way AA uses the 772 now, it could result in lower overall costs.
Of course part of the equation is that AA really would like to use the 777s on more longhaul international flights - they have already said that - but can't because of their labor cost problems - or at least that they refuse to significantly grow the company until they get labor agreements that they believe are suitable.
So, for now, that leaves them ordering 738s only at a rate large enough to avoid a huge replacement cycle of M80s in 5 years when hopefully they can begin buying new bodies and use them closer to the way those planes are intended to be used.
