WorldTraveler
Corn Field
- Dec 5, 2003
Jim (BoeingBoy),AA should definitely stay away from the A333's - they don't have the range for anything other than mid-US to western Europe. or JFK-Europe. US doesn't even use them for PHL-ATH because it would require weight restrictions pretty much all the time on the westbound. A fleet composed of 738/9's, 78X's and 777's would cover pretty much all the flying AA is likely to do other than something in the 90-130 seat category (assuming that 50-70 seat segment is operated by a RJ operator).
do you realize that there will be more than 8 markets served by the 333 as of this summer that will be longer than 5000 miles and all have block times in at least one direction greater than 10.5 hrs in at least one direction. The longest will be LAX-NRT on DL which has a block time westbound of 11.45. Given that DL also has 332s and has operated them for years on LAXNRT, why would DL put a 333 on it only to have weight restrictions when they can operate a 332 which does not have weight restrictions? (KE will also be operated LAXICN on a 332 this year and the longest 332 flight by block time is QF's LAXAKL at 13.5 hrs) Further, DL has the highest density of seats on the 333 of any of the operators with flights over 5000 miles. DL has operated ATL-FCO for the past 2 years and sells the entire 298 seats. Even though LH has a lower seat config, they also have other aircraft that should not need to be weight restricted.
Here are the list of markets:
DL ATLFCO, KIXSEA, LAXNRT
LH FRASEA, MIAMUC
OZ ICNSEA
WK CUNZRH, YVRZRH
But again, I never suggested AA should use the 333 for transpac use; I said that the 333 was more than capable of flying most of AA's LHR and S. America flights which are less than 10 hr or 4500 mile flights. If you look at the list of flights that meet that threshold and are operated by carriers around the world, the list is quite long and also includes AC, AY, CI, CZ, QF, LX, MU, QR, and SU.
I am not a salesman for Airbus. I am simply saying that the notion that fleet complexity runs up costs has to be weighed against the reality that aircraft like the 333 could dramatically reduce AA's costs - likely far more so than the value of operating a more "simple" fleet. AA's unions (or at least one) said that AA had wasted X amount of money by not replacing the M80s sooner and even AA did not make fair comparisons between M80 and 738 total costs. Given that there are 333 operators in the USA and they report their costs to the DOT, it is indeed possible to see that the 333 is a much lower CASM aircraft than any other widebody.
The AA union(s) could have just as easily asked why AA did not trade in their A300s for a fleet of 333s that could be used for midwest/eastern US to LHR as well as MIA-deep S. America.
Of course AA will have all of the fleet they need with the 3 types you mention, but they will never have ONLY those 3 types... there will be other fleet types
both older and newer than the 3 above during periods of transition. And that is also part of my point and even then, the 789 may not be the most economical choice for operating flights under 4500 miles - and it likely will be smaller than the 333.
Good business requires being open to consider all kinds of alternatives and to doggedly pursue each option - and then not be afraid to eliminate them based on good business sense and not emotion.
I'm not convinced that AA's decision to ground the A300s and to not consider other Airbus products - and its urge to get rid of the M80s - is driven somewhat by emotion.
I still say the fastest way to get Boeing to commit to a new narrowbody would be for AA and DL - among others - to get really serious about ordering the A320NEO.
Jimntx,
I have not been on a 150 seat DL M80 but given that they are removing a galley in order to make the space for extra seats, I'm not sure that the increased seating density is going to be that less comfortable. Given that the last 25 people on either AA or DL's M80s end up having to gate check their rollerboards, that problem is not going to get any better.
