E
		EastUS
Guest
Those pilots should share what they know because maybe my captain tonight will put on less fuel because of something he wasn't aware of.
"that would be SOME pilots, do engage in intentual fuel burning and they have been reported and called-in in the past" "Called in"? That's news to me, but even if at all true: WHAT does that have to do with any supposed "Training"?
"I do not know who these pilots are."..BUT..we should all cheerfully support their "Right" to be suspected of some wrong doing?..Because some "friend" of yours saiys so? I just love this sort of "reasoning" = ANYONE has the "Right" to be a "Suspect"..and all that's needed is for ANYONE else to cry "Witch!".."Heretic!!"..or even just have a "friend" that does so..and The Inquisition's "properly" ON!!!..
"Maybe they do have the best and safest intentions in mind, But if not then what harm is it to find out."...."If they are doing nothing then let's find out."
What's your suggestion? Waterboarding?...Electrodes?..What? Vee haff Vays uf making you talk?? It scarely takes any lenghty inquisition to realize that 15 or so more minutes of fuel..over a minimum of a 7 hour leg...isn't any excessive increase, and a mutlitude of factors can not only justify such as a very rational act, but even reasonably demand it being done.
"If they are doing nothing then let's find out." Who's "let's" in this case? Are you qualified to evaluate fuel planning issues, or is it sufficient that you've a "friend" that shot off his/her mouth for you to accuse, or even be reasonably concerned? Feel free to bring your "friend' forward, and I'm sure many will be all ears as to that person's take on the issue...and why...
"Those pilots should share what they know because maybe my captain tonight will put on less fuel because of something he wasn't aware of."Less fuel?..I thought you were upset about adding fuel...? That makes almost as much sense as your rather strange, slide deployment comparison. You might wish to reconsider that particularly bizarre "example" of yours. I'd submit that having all the slides dragging outside the plane would increase the drag a bit, and consequently the fuel consumption. 😉
