WorldTraveler
Corn Field
- Dec 5, 2003
Kevin,No I didn't. You've decided that's what I said in order to promote your idea of how the discussion should go.
I have said that the CRP is wholly ineffectual since no matter the verdict delivered by one's peers, it can always be overturned by mgmt.
Systems such as the CRP & FIT/EIG teams are paper tigers designed to give the illusion that employees have an actual say. DL is not the first company to use them, nor will they be the last.
One cannot also their seniority to freely move back and forth between departments. This is something the company explicitly promoted as an improvement over classification seniority. It simply doesn't happen that way.
In a RIF, you do not own your seniority; the company tells you where you can or cannot go (if anywhere). If you want to move from the ramp to the counter, you also have to interview.
My writing something that doesn't mesh with your narrative does not mean it's false.
This is the quote I made.
This is your response:I know EXACTLY what protections DL contract and non-contract employees have.
Perhaps a little more than a one sentence reply to the topic would have removed any doubt as to what you meant.Then you know the answer for the latter group is "none."
If you knew there was an appeals process, then it is not accurate to argue that DL employees don’t have any protection.
If you believe the systems have are inadequate, that is your opinion and I will most certainly recognize your ability to come to that assessment.
IN the absence of any concrete data about which system “saved” more jobs, then it is a subjective assessment on both of our parts as to which system is better. And I will not argue you with you about which is better.
I will present historically verifiable data about which airline saved more jobs in BK.
I will also note the objective fact that your colleagues do not believe that the concerns you have about job protection from DL are credible or at least on balance with the entire employment “contract” (whether one actually exists or not) is worth hiring a union to attempt to regain those rights.
To reinforce the issue Glenn raised, I absolutely do value the opinions and thought processes of each person on this forum and I respect the passion each person has for what they believe, and that includes you.
I truly want you and Glenn and Dawg and Southwind and every other DL employee – and not just DL employees – to achieve what they want… but we also have to learn to work within an environment that doesn’t give us all we want. There are clearly a lot of your DL colleagues who agree with you but there are clearly more that do not – or least do not believe a union is the answer.
If you (each of you) want to stay at DL – and I see no indication you do not – then you have to figure out how to work within a system that is obviously not totally to your liking. I want you to win – each of you. But sometimes winning means shifting the priorities you have, recognizing you might not achieve them in your current environment, or focusing your energies on another environment where your chances of obtaining what you want is far greater.
Forgive me, Kev, if I misinterpreted what you said or unfairly characterized your assessment of the situation.
