mweiss said:
We could argue this point for weeks. The stack ranking is not as clear as that.
[post="258620"][/post]
Actually, according to the NHTSA, the primary type of accidents in which excessive speed has been the primary causal factor was single vehicle accidents in which the excessive speed resulted in loss of control, so I'm comfortable with my position.
mweiss said:
Among aircraft mechanics (i.e., within the craft), this is true. However, among aircraft engineers, the same statement is false. Are you saying that you're right and they're wrong?
No, because I don't accept the premise that their standards are different. You say that aircraft mechanics and aircraft engineers have different standards of safety, yet the standards the mechanics use are those determined by the engineers.
And yet WN manages to be more productive across all lines of the business. Clearly they're doing something right in that regard. I'd be more inclined to buy the apples-and-oranges argument if it weren't consistent.
I did not say they were not more efficient, I said that the standard you attempted to apply was skewed and therefore invalid and that the many people that I know who work there say that the differences, at least in maintenance, are slight.
And why would someone do more than the minimums?
Because experience and different operating environments have shown them that while the minimum may be acceptable in one circumstance it is not acceptable in all circumstances. For instance, different airlines operating the same airplanes in different weather environments will have different standards for acceptable brake and tire wear based on anticipated RTO conditions. Also, even whether an airline owns it's tires or simply leases them can be a determining factor, as allowing an aircraft tire to wear to minimums increases the risk that it will be worn too badly to recap, something a lessor cares less about.
After all, the minimums are "safe," and doing more than that, according to you, isn't any "safer". Therefore, you must believe that doing more than the minimums is throwing money away.
That is a extreme misinterpretation of what I said, and it should in no way be attributed to me. The conclusion you reach is so incorrect as to be an insult and, at best, represents a logical fallacy because it takes the conclusion,
C, to a result not predicated by either proposition
A or
B. Indeed, your proposition
B, "...and doing more than that, according to you, isn't any "safer".", is directly opposite of the point I have been trying to make.
I said that the safety of the aircraft is the sum of the safety of its parts and, earlier, said that by their standards the manufacturer would consider an airplane with every part at minimums airworthy or 'safe'. Yet the minimums allowable for one part are often relative to the condition of another part, or have a time limitation on the amount of time they're allowed to be at minimums, so even the manufacturer understands that 'safe' can be 'safer'.
I will go so far as to say that I believe that an 100% 'safe' aircraft is impossible to achieve, because the complexity of the machine involved virtually guarantees that even a brand new airplane has one broken or 'unsafe' part. However, differences in the state of the sum of the parts from aircraft to aircraft, and the nature of which part is 'unsafe', determines the overall state of the aircraft.
When talking about maintenance programs in general, whether the minimums are acceptable is left to the FAA, and no carrier that I am aware of is allowed to do the absolute minimum in every case.
Contrary to your conclusion, I believe that doing the absolute minimum is unsafe because the act of operating a part worn to minimums guarantees that it will exceed minimums. It is also throwing money away, because if you run every part until failure and repair none, it is far more expensive than removing them before failure and repairing them.
In fact, it is from these discussions that I came to realize that the chain of events would often be broken had just one system been above the minimums. Yet an AMT wouldn't have considered the aircraft to be any safer. Why is that?
Again, a radical misinterpretation of the text. An AMT would be the one to determine whether the system was within limits, or as you put it, "above the minimums", or out of limits ("below the minimums") in the first place. He would be placing his license, his future and the future of his family on the line when he did so. Like the pilots we are liable both administratively and also in criminal and civil court for our actions, but unlike the pilots we are usually around to suffer the consequences
You say that "In fact, it is from these discussions that I came to realize that the chain of events would often be broken had just one system been above the minimums.", yet you are the one seeking to justify the reduction of maintenance to the minimums, not I. An interesting dichotomy, don't you think?
Rather, I mean to imply that the customers' perception is that it does. Since they're paying the bills...
So how do you convince them to pay for better maintenance?
While the customer does have a serious influence on pricing, I still say that they do not have that much influence on how an airline spends the money it does take in, so I remain unconvinced that it is they that we need to convince. While the public certainly has an influence on the marketeers who run the airlines, the politicians who write the laws and the bureaucrats who, ostensibly, enforce them, I am not certain that the time effort and money required to educate and convince them would result in a proportionally worthwhile outcome. I would expect such efforts to be dismissed by the authorities as 'union propoganda' and the usual number of 'spokespersons' be deployed to refute them and explain that "the emperor" was, indeed, "fully clothed".
Even as Valujet was burning up aircraft taxiing on the ramp and taking maintenance delays on almost every flight, people were lining up to fly them. Even after a planeful got killed for their troubles, anyone who stated publicly that a Valujet passenger might be unsafe - even as the FAA moved to ground the entire airline - was dismissed as an alarmist. The conventional wisdom was that they were safe and even after the conventional wisdom had killed a planeful of people, the conventional wisdom was not to be refuted.
As for getting anyone to pay for BETTER maintenance, we're too busy trying to keep the standards from becoming WORSE to worry about BETTER.
