Sometimes I forget that your interest isn't in actual discussion and context, but rather in some bizarre quest to dominate this little corner of the web.I'm trying to figure what PDX has to do with anything. can you help us out? If DL doesn't rely on AS to feed it and uses its NRT hub, what does it have to do with the AS discussion.
maybe there is some connection and if there is, I'm more than happy to hear it.
Kev3188 said:Sometimes I forget that your interest isn't in actual discussion and context, but rather in some bizarre quest to dominate this little corner of the web.
Yes, because isolationism has worked out so well historically...WorldTraveler said:DL is actually in a pretty strong position if it can start thinning its partnerships down to the most valuable and in letting others know that they offer nothing to DL and benefits will be cut.
eolesen said:The interchange was also post-deregulation. Braniff operated the interchange until they imploded, and AS switched over to AA in 1982.
I could care less about an infographic prepared by a marketing weenie. The fact remains that AA and AS were in a commercial partnership for almost a decade prior to the codesharing with NW & QX.
Nothing spells partnership like having an AS crew flying an AA aircraft north of SEA, or an AA crew flying an AS aircraft south of SEA.
