WorldTraveler
Corn Field
- Dec 5, 2003
since DL isn't using 767s from JFK to Asia, it is no more of a point than to say that it can't fly to HKG form the mainland because DL isn't proposing that usage either.
I get your need to see heavy metal flying the Pacific = just like what AA and UA do.
DL's 5th floor types don't care if other carriers fly heavier aircraft than DL.
DL's philosophy has always been to use smaller, lighter aircraft to the extent of the smaller aircraft's limitations.
DL will order 787s or 350s alongside used older generation aircraft and they will fly the Pacific alongside 330s.... that is just reality as much as you want to think otherwise.
the 330 is and will be used as a TPAC aircraft either in the current low weight 332 and 333 versions and the higher weight 333s. DL knows the capabilities of each type and will use each where it makes sense.
The 333 will be a key aircraft DL will use to change the economics of the NRT operation; I believe DL quoted a statistic such that the 333 will reduce costs by $100 million per year compared to the 744.
