- Thread Starter
- Thread starter
- #31
It's certainly well-timed for PHX or LAX.etops1 said:Is it far fetched to say that we may see PHX getting this slot ?
because AA employees do not work on BA flights.In a metal-neutral JV, why does it matter who operates the route?
Operationally and slot-wise, it probably matters, but certainly not for a marketing or revenue standpoint.
I remember American flight attendants worked Alaska Airlines metal on flights from DFW to SEA in the early nineties. These were flights on our bid sheets. Cannot remember if the pilots were American or Alaskan Airlines. Did not like working them as we had to run everything, they had no service carts.from a ground handling perspective, so far as I know.
I'm talking pilots and FAs. There is no US airline that I know of that has crewmembers of other carriers working their flights.
Thus, metal neutral does not necessarily mean the same for employees or even customers.
And here is WT's postThe bigger issue perhaps is that too many people on a.net have not turned the corner and realized that the aviation market is changing and DL is leading the change.
There is no viable financial reason why DL should operate its own aircraft in JFK-CDG when AF can do it effectively and free up DL to use its resources to open other routes, many of which will benefit AF.
AF will not use its resources to start a route like JFK-AGP. DL opened the market and is doing very well on the route. In time (not this phase), AF will enjoy some of the profits from that route.
It is time to quit thinking of airlines in terms of lines between cities on a route map and see them instead as businesses that produce the greatest return for their investors.
If AF and DL can generate better returns for each other by DL dropping NYC-PAR, they should be commended for moving the airline industry to a profitable, future-focused paradigm.
You want people to maintain consistent positions when they drone on and on about their former employer compared to the competition?MAH4546 said:Guys, it's only relevant when AA isn't using it's metal on the JV. When Delta exits markets like JFKCDG, that's totally cool.
Quoting WorldTraveller himself, see post 44:
http://www.airliners.net/aviation-forums/general_aviation/read.main/4095458/
Yep, no double standard whatsoever...There is no viable financial reason why DL should operate its own aircraft in JFK-CDG when AF can do it effectively and free up DL to use its resources to open other routes, many of which will benefit AF.
