On 7/9/2003 11:51:11 AM MarkMyWords wrote:
Let's see. If we follow your logic, then why don't we completely close PHL and move the operations to Mid-America airport? The terminal was built and never (or rarely) used. That would solve a lot of our issues. Bottomline, you put the airplanes where the revenue is.Â
I understand that the PHL manpower issue is being addressed. the Ramp Manager and the Performance and Planning Manager are both being replaced. Hopefully this will help the situation.Â
Marky,
I've been reading your posts of late...and your starting to worry me.
Your thinking, if you follow it through, doesn't make sense. To fire the ramp manager or performance manager, has to do with the VP of that department trying to cover his ### for instituting poor policies, and cutting too many folks. So, what ingeneousness or profound insight will another manager offer, that should be thought out by an already VP. Answer to said problem: GET RID OF THE VP!
Just read an e-mail that I was bcc in by a f/a addressed to Siegel. The f/a was citing that the airplane from MCO to CLT, that left around noon was so dirty he couldn't believe his eyes. He continued to write that it is so obvious that this management has cut too many cleaners, and this is not the first time he is seeing this. This was just one example.
Reply from Siegel verbatim:
" I can tell you that staffing is adequate, so it may be a compliance issue.
Our a/c cleaning stats are up dramatically now that we are measuring and
managing the process.
I will follow up specifically on this incident and get the stats on
cleaning to you
Thanks for your input"
Dave
_____
So, you see, that mangement is "managing the process". This above just happens to deal with the cleaning of a/c, but the true issue is this is someone from the "tippy top" who views a problem from a distance. He automatically thinks that it MUST be a compliance issue, which translates to employee discipline. He will not admit that he furloughed too many folks and now the service is suffering. He believes, in his small Harvard mind, that one person must have the task of many, and perform at the same rate and level taking full responsibility, taking no consideration to the fact that our business IS "time sensitive".
We have a problem in Houston...and its at the TOP. They need to get involved in the process from UP CLOSE.
