Bambi
- Sep 17, 2005
- 88
- 0
Any help from US rez agents in encouraging our new management team to at least help HP rez come up to your current payscale. I realize the major cuts you all have taken over the years. I also realize I knew the payscale (which has changed drastically over the past few years) when I was hired. However, we see this merger as a $ maker for the execs but the "little guy" isn't getting any incentives to stick this thing thru.
Of course, writing to both UNIONS on this CWA and Teamsters would also be helpful.
Question: I hear you are having to learn HP QIK-REZ and QIK-Check (at ato) systems. Has this already started? It may seem a little confusing at first, but once you learn QIK, you will NOT want to go back to anything else.
We have agents who have been here since the beginning (when HP did everything in SHARES). They say that this program is still tops on their list. Only difference with QIK is if you're in REZ you can't use any SHARES codes unless you have a SUPervisor sign. I think RA (rez assistance - fornerly QM) can do this though
