sharktooth
- Jan 27, 2006
You are starting to resemble your avatar in every way imaginable. In fact, now that our favorite Spinmeister has been sent to the cornfield by USAirways management, I crown you as his replacement.
You didn't answer my question, in your heated effort to discredit me. Why did you refuse to take the trip without an IRO? We fly around Class II airspace every day with no IRO. Maybe you are the one that needs to brush up on the regs.
The regs state that any leg over 8 hours requires more than two pilots.
An EOW (equipped aircraft over water) PHL to SJU is scheduled less than 8 hours, and requires two pilots, minimum.
A NON-EOW aircraft, 321 and NON-EOW 757 may not transit class II airspace and require a trip down to the bahamas, then over to SJU, total time, over 8 hours. They must remain within 162 nautical miles from any dry land (mean low water). That extra distance would require an extra pilot, commonly referred to as an IRO.
You would benefit by reading the FARs as there are a lot of extra gotchas within the regs.
Try enhancing your skills rather than shoving your ignorance under the nearest carpet because it really demeans you, and the rest of us that call you "brother".
Interesting that the poster you condemn to the cornfield would never have made the potentially fatal mistake you seem intent on defending.
