777 fixer
- Jul 21, 2004
And where have you come up with this "140lbs high explosive continuous rod warhead" thing? :huh:
Have you been paying attention? Why don’t you look it up.
Since you are the one who mentioned the Navy I thought I would point out to you how unlikely that was. First by mentioning that the SAM’s typically used on Navy ships are of the semi-active kind. In other words they have to be guided to the target. Turn off the guidance and the missile goes dumb. Then there’s the issue of the war head. A 140lbs of explosive with steel spikes is going to leave its mark. Yet no such marks were found anywhere on the airframe.
TWA Flt.800, left the gate late that night. A second 747 was delayed also! EL AL! Flt.800 took it's slot!-----It just happened to be in the wrong spot, at the wrong time! Second, How do you know what the Navy had in the way of "Surface to Air Missiles" back then? Or even if they had warheads on them at all! From what I've been told a missile penetrated the center fuel tank causing it to explode. The missile itself was the ignition source of the fuel vapors! Not necessarily a war head! And that was evident by the way the "Keel beam", deformed. The NTSB insists it was due to an electric spark in the center fuel tank. But, the only wiring in that tank goes to the fuel quantity probes. And the currant that runs through them is measure in millivolt's! Not enough to create a spark! So the NTSB came up with a theory that maybe some of the fuel prob wiring were in a wire bundle with high power cables that somehow bleed over and caused a power surge! Problem with that theory is that Boeing purposely doesn't route those fuel probe wires that way for that vary reason! Remember the fuel we're talking about is "KEROSENE"! Did you know they took an old 747 fuselage out to the desert and tryed duplicate the explosion! Guess what! They couldn't!
