Cirrus To Issue SB On Brake Overheating, Fires
Sport_AV
Advanced
Cirrus Design plans to issue a Service Bulletin on all its aircraft in response to a spate of brake fires (the most recent of which occurred Dec. 9) that have caused serious damage to at least five aircraft. The SB will call for the installation of color-changing temperature sensors on the brake components so that pilots can tell -- during the preflight -- if the brakes have been previously overheated. Cirrus spokesman Ian Bentley said overheating can cause failure of an O-ring. Failure of the O-ring allows flammable brake fluid to leak onto potentially hot parts. If they're hot enough, the brake fluid ignites and causes a stubborn fire that can really make a mess of a low-wing plastic airplane.
http://www.avweb.com/newswire/11_52a/leadn...tml?CMP=OTC-RSS
